Got a bit of left over stuff out of my spare room,
Just a few things i wont be needing anymore...
Standard carbon finish GTR Dash cluster, little over 100,xxx k's on it - $150 posted
Standard carbon finish Centre Gauges - $100 posted
Standard Vspec Suspension - $300 posted (would have to use courier)
Standard Headlights, looking a little yellow, could be polished up so i've heard, - $70 posted
Standard GTR Cooler - $250 posted
Brand new R33 GTR Boss kit, for airbag.. Has a wire for tricking airbag light - $100 posted
Brand new MOMO Trek Steering wheel in Black - $250 posted
Also have spare orange standard gtr front indicators out of bar - make me an offer i guess??
Will Get Some Pics up later on today...
Cheers...
https://www.sau.com.au/forums/topic/277776-r33-gtr-bits-and-pieces/
  • 3 weeks later...
  • 3 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
