Was interested to see if my V35 could run on E10 but according to this website only post 2004 model can?
Now from what I know theres no diff betwean a 03 and an 04 V35
So did nissan change its fuel lines or injectors or something after 2004?
https://www.sau.com.au/forums/topic/278095-can-we-run-e10-in-the-v35/
Dunno mate, but I guess it doesn't matter.
Shell has already stopped making their E5 100RON Optimax Extreme fuel,
and most E10 fuel out there sold by independent fuel retailers are based
on regular unleaded with around 95 or 96 RON.
You'd still be better using 98RON BP Ultimate/Mobil Synergy 9000/Shell Optimax from the RON point of view....
Well i was wondering cus up here in far north qld there is a lot of stations that sell E10 95/96 petrol @ the same price as regular if not cheeper which is usualy about 20c per L cheeper than optimax or ultimate 98
try it for a few weeks and see what happens.
you will get less kms and you will feel your car doesnt like it.
Japan has a very high grade RON fuel and the computers know this (learnin computers)
it is best to you the top grade fuel if possible.
Your car will love you for it and you wont get all the crap left in your motor that lower grade fuels give you.
Have never ran it in the V35's i had, but have used it for a little while in my 04 Maxima and i wouldn't recommend it. Regardless of what Nissan says.
I noticed the Max started pinging a little off the lights under load, and after looking into it, found that Nissan Aus where only recommending certain brands of 98 Octane for the VQ35. Even though the Maxima's are listed as ok for E10, and that 95 is also ok.
Looking into it more, I'm finding the VQ35's are very sensitive to fuel.
Off the top of my head, the recommended fuel was either BP, Caltex or Mobil. People were still have probs with Shell apparantly.
I also used shell when i had the V35, and didn't notice any probs.
I'm strictly just going off what a few different Nissan service guys have said in different states.
Pretty much all agreed that the VQ35's (in the Maxima's) only ran as they should on 98, and it was common that Shell wasn't a preferred fuel.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
