Hi
I just brough a pair of adjustable castor rods for my R32 GTR and I noticed that the ones that I have recieved are straight. my question is doesnt the GTR castor rods have a bend in them (to avoid some suspenion component, i cant really remember) or do the adjustable ones have some type of offset to avoid this bend?
Cheers
Fil.
https://www.sau.com.au/forums/topic/278234-quick-castor-rod-question/
yes the GTR castors rods should have a bend in them. most likely you've got 32 GTST ones instead. perhaps some aftermarket makers don't make actual 32 GTR ones, but the aftermarket ones I've bought had the bend. (except for the ikeya ones which come with their LCAs as they are completely different design).
good man. and good memory. I had a set of the cuscos too and couldn't remember but now that you mention it I do remeber thinking how clever of them. the little "cones" that fit into the rod end are different sized to offset the position of it in the bracket at the front. thus negating the need for the bend. BUT the china ones I had tried once (for about 2 weeks!) did make bent ones for GTR and straight ones for GTST.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
