All parts preferred pickup from Central Coast NSW but can organise postage costs.
I have two standard turbos from R32 GTS-4/GTS-T.
One has done around 100,000 KMs before i upgraded turbos and was fitted to a manual R32 GTS-4 which i bought with 89,000 kms and i never boosted.
The other around 110,000 KMs from a motor i just bought from Just Jap, its was fitted to a auto R32 GTS-4.
Both have dump pipes and turbo elbows.
NETHER HAVE ANY SHAFT PLAY!! $150 Each
Mines ECU to suit GTS-4 with 444cc injectors and TD05-16G or KKR430 or similar. Removes speed limiter an boost limiter too.
Not needed due to other plans with engine management. Photos to come.
$250.00 ONO
Standard Coil cover to suit R32 GTS-4/GTS-T. $20.00 ONO
Standard cross over pipe to suit R32 GTS-4/GTS-T. $60.00 ONO
Standard intake pipe to suit R32 GTS-4/GTS-t. $40.00 ONO
Standard R32 GTS-T Red Wine Wing. $30.00 ONO
Full set with spare (21) plus socket of Aluminium Light Weight TurboXS Gold Wheel nuts to suit any Nissan.
Used for 3000 to 5000 km then bought new wheels and didnt fit any more. Cost $130. $50.00 ONO
All funds go to the get Bens stupid car fixed fund, which i broke.......
You can contact me through forum or on 0410 457 644.
ALSO
TurboXS Anodized billet aluminum shift knob Matte finish with mirror-finish TurboXS logo
M12 x 1.25 to suit Toyota/Subaru. Cost $80.00. Photo coming.
$15.00 ONO
More engine bits coming such as R32 GTS-4 front diff and sump, RB20DET head, RB20DET injectors and standard exhaust manifold to name a few. If anyones interested in anything let me know as will have a complete RB20DET minus turbo with blown bottom end once pulled out of my car in next few weeks.
Be quick if anyone is interested as im going to list everything on ebay pretty soon as i need it sold.
Everything is slowly going ebay.
Both turbos are listed, Search for "standard turbo R32" starting price $50.00 each!
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
