ok put a new engine in my skyline rb20gts-t. started it... started ok for couple of days. then last two days when its cold it starts fine cranks over and runs on idle fine then i turn it off after 30min....go to put car in garage it wont start. cranks fine but no start..i have put new spark plugs, coil packs. the car is getting fuel so not fuel problem. changed computer so not computer. took oil cooler off cause i thought i could have connected it wrong. still same.. so what do you guys think? please help. could it be crank sensor? but if it was it wouldn't have started right?
cheers
car has bosch fuel pump, gt2876rturbo, full exhaust, pod filter, stock computer, fmic, if you need that info.
https://www.sau.com.au/forums/topic/278458-engine-starts-and-cant-start-again/
only starts when cold? sounds like my old car
Get the injectors cleaned out, it's not spraying enough fuel on start up hence the car isn't starting, when the car is warm, there is no fuel compensation.
Also, is your PCV plumped back into your cam covers and intake? having an atmospheric catch can setup and the PCV still installed will also cause problems when there's no positive pressure in the plenum.
yes only starts when its cold. and when it starts i run for 20-30 min switch it off. then i cant start it again. just cranks over.
i dought the injectors will need a clean, the car does start only when cold though, but i will check with mechanic about injectors, edit: with injectors they are pumping petrol as i can smell it heaps when it cranks.
whats a pcv?and i dont have a catch can,
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
