hey all time to sell my silvia due to no licence.... i dont really want to but i have to so i can get a less cop attractive car. weve owned the car for 4 years. it use to have a humble ca auto. car has only seen the drift track once and was a hell of a lot of fun if i could id do it every day. car is fast as and has gotten me to and from work for the past 6 months. drove it to QR with a full tank of gas and full of tyres and didnt miss a beat. car gets good reports from all crowds and attracts some good attention. as i said i dont really wanna sell it but i can do with some more money. also beats evos skylines and ss's lol . mod list is as follows. Car also got defected so will hav to get that sorted. I HAVE SPOKEN TO QLD TRANSPORT AFTER DE REGISTERING MY CAR AND THEY SAID JUST GET A RWC AND IT CAN BE REGOD NO PROBLEMS.
0414 853 859
1991 S13
Black Roof Black Bonnet Black Boot Maroon Rest ( JUST SPRAYED ABOUT 3 MONTHS AGO )
RB25DET
FMIC
Modified Inlet Plenum
Spitfire Coilpacks
Aluminium Radiator
Twinm Thermos
Oil Catch Can
3" exhaust Cat Back With Twin 3 " Kicks
TIGHT ARSE Shimmed DIff
Cusco Adjustable Castoir Arms
G4 Coilovers
GTR Front Brakes
5 Stud All Round
Rear Strut Brace
10.5 " Wide Rear Tyres
Square Head Lights
Strobes
DRIFTBLITZ Seat
SABELT 4 Point Harness
1 x Defi Style Boost Gauge
1 x Defi Style Oil Temp Gauge
1 x Defi Style Oil Pressure Gauge
1 x Defi Style Water Temp Gauge
TRUST Gear Knob
Nardi Wheel
Stripped From Backseats Back ( i do have all the interior if need be )
URAS Front Bar
URAS Side Skirts
URAS Rear Bar
Fibreglass Bonnet
Tripple Widebody Rear ( Original Guards Still Under There Just Been Rolled )
Fibreglass Fronts
5% Window Tint
Alarm System With Built In Turbo Timer
