hi guys, ive got a r33 Gts that im soon to get resprayed and a kit fitted to.
id just like some opinions on what sides and rear would look good on my car and where i could buy them from in melbourne.
atm i have a Trust(i think) front bar, and GTR rear wing.
im liking the look of the veilside style rear bar and the 400R style sides but im worried about the heights not matching up.
any 1 know if they will/wont line up? or any other rear/sides that will look or fit better??
thanx ppl
https://www.sau.com.au/forums/topic/279045-skirts-for-r33-gtst/
:) Get a new front bar too mate that thing is hideous. Sorry honesty is the best policy.
Also the veilside rear bar is probably the ugliest rear made for the r33. At the end of the day get what you like even if it is bad taste.
Why dont you have a search of all the available body kits on the r33. You will soon see...
The veilside rear bar probably wont match up with the 400r sides level.
thanx for the critisism guys.
i doubt ill worry about changing the front bar atm. but since i have to get the rear bar sprayed im thinking i should get a new 1 now with sum sides.
can u point me in the right direction for sites wit 400R and Do-luck in melbourne so i can have a look?
i got my do luck kit from DMD the image in QLD. Was happy with there work. My rear was a jun though i didnt like the do luck rear bar. Try this site
http://www.ebridge.com.au/dmdtheimage/
Note some of there kits a wrong in pictures. Eg the 400r shows the 400r front bar but the sides are different. Just use another site or search for those bodykits listed on there site to see what they look like. They are very well priced.
Edited by Pattygtst
You may as well get a new full kit if your getting sides and rear. You can get package deals with dmd. It might not cost you any extra for the front or a minimal amount.
how much was ur kit through DMD? can u pm me the price?
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
