Hi All,
(Chris Rogers may be the DA MAN for this)...
I have a 2003 V35 sedan with the BOSE system and the steering wheel controls on the left hand side, see pic attached.
Now, I am maybe one of the unlucky few that had my factory monitor, etc removed and had an after market Panasonic HDD SatNav and 7" LCD installed (which is 'useless' and only used for the reverse camera). I will be removing the whole system and will be buying a 2 DIN Fascia to install a Sony headunit and motorised LCD screen in lieu of the BOSE 6 Stack CD/Tape Player.
I have already found the Fascia and the wire harness to connect up to the BOSE Amp and speaker system. However, from the same seller, they claim to have a steering wheel control interface that retains the use of the factory steering wheel controls (and mates it to the Sony headunit). However, this unit is for the G35 Infiniti and they cannot confirm if it works on the V35. But, going through their Tech Notes, it seems that this "may" work on the V35.
See here:
http://76.12.243.71/swixprogramming/showst...cles&ID=211
And here:
http://www.pac-audio.com/PACProductData/SW...ions_061407.pdf
My question is:
1. By reading the info in the 2 links, can any Tech person confirm the wiring harness is the same, etc.
2. Is anyone willing to install this for me?
Like I said, Chris may be DA MAN for this job, but before I go spending $100USD on this unit, I need some assurance that it will work.
If this works on my car, it means that it will open the floodgates for many other V35 owners to explore changing their headunits and utilising the same factory steering wheel controls...
Edited by siu_loong_bao
Oops, one more thing, can someone also confirm if the USA G35's Bose system wiring harness is the same as the V35s?
The kit comes with 2 wiring harnesses, which u only need to use 1 (depending on your aftermarket head unit install).
In my memory reference for Chris. The Harnesses of G35 bose and V35 Bose is different. So the US kit does not support JDM model. But Chris has his own harnesses can to the same job. Send him a pm, he will do the job for you.
+1.
bearing in mind a lot of the G35 stuff does not apply to this car. the leads you show DEFINITELY do not.
SWC - yep you can retain that with a sony stereo. I would be wary of ebay though. buy it off someone local.
+1.
In saying all this, what is actually required to replace the stereo only on a V35? not interested in combining monitor or navigation, just a repalce of the bose head unit with something else?
Hi Ther
Just in case if you have no idear wht Chris talk about.
Here is the picture.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
