Hi everyone,
I had a 3" trust pe2 catback installed on my r34 gtt. Somehow i feel like the car rev slower than before. therefore i wonder if anyone else here had the same catback exhaust installed and how far they can go in performance.
It is very quiet. But i'm not sure about the performance.
My car has few mod: pod filter, catback and fmic.
https://www.sau.com.au/forums/topic/279310-trust-pe-2-catback-exhaust/
Its more or less the same as the HKS Hi Power, but has a larger center muffler.
A mate of mine is using one on his R33, 270rwkw. Doesnt seem to hold it back at all.
Has he got a dump/front pipe on it? Trust PE2 as well?
I'm running a Garrett GT3076R on it so you can't run a stock dump pipe on it, I have front pipe as well. Is an awesome sounding exhaust with the bigger turbo as well :mellow:
I went from a Nismo exhaust on my 34GTT.. to the Trust PE II with the BatMBL split-dump pipe + 3" cat... you can see the video of the install here :
And it felt a hell of alot better.. although I think that was mainly due to the split-dump pipe. I'd highly recommend doing the dump and the cat in conjunction with this exhaust.
This white r33 makes 330rwkw with a Titanuim 90mm racing system and makes 225rwkw through a PEII so resriction should not be too much of an issue :mellow:
http://www.statustuning.com/sections/images/gallery5.jpg
yeh i hve a trust PE2 :mellow: its very good im doing 230kws on it :( its not loud, but when you want it loud u can make it loud :(
i see.. thx everyone for let me know that it is a good exhaust anyway..
so geraus, you got a dump/front pipe in order to make 230kws on it right?
it's really nice to get help from everyone here as i'm a newbie to turbo.. :)
This white r33 makes 330rwkw with a Titanuim 90mm racing system and makes 325rwkw through a PEII so resriction should not be too much of an issue :iluvff:
edited, sorry i mis-typed. it should have read 330- 325rwkw NOT 330rwkw - 225rwkw :D
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
