Looking for a set of shocks and springs or coilover for an R32 GTR. Doesnt need the best as I will only need it to last a year or so till I can afford to put on a new set.
Not looking for leaking or knocking suspension as it would be worse then my current ones.
Pictures would be nice.
Thanks.
https://www.sau.com.au/forums/topic/279415-r32-gtr-suspension/
Pair of Nismo GTR R32 rear progressive rate spring units, and, a pair of Trust brand adujstable damper with progressive rate springs.Come off a R32GTR 1993
The Pro springs start off at approx 6kgs, then stiffen up to 8kgs under load, so not super hard bone shakers, but when driven quickly, they get stiffer.
No leaks/knocks, very clean, no paint chips etc.
$400 the lot ( all four)plus postage!!!, or,
I can deliver to Sydney (Oran Park Raceway) next weekend, you will have to meet me there to collect them!
will require bank deposit as I'm not gonna cart them all the way there for a no-show
  • 3 weeks later...
Still interested in any offers. Dont really need springs, just struts. Coilovers are ok, but prefer struts. Would help if you supplied a picture and please dont offer me standard shocks, ive already got 3 sets and they are all rooted.
Cheers!
I've got some KYB coil overy type things. In a box at work so can't really show you them now. I'm not sure how old they are but they were on my R32 GTR when I got it. I've upgraded to DMS 50mm. The KYBs worked fine and aren't leaking etc. Perfectly serviceable. Let me know if you want to know more.
hey mate,
dont know if its wat your aiming for but i have a full set of r32 gtr JIC flt a2 coilovers in immaculate cond, willing to post em at your expense for $ 950 firm as i payed $1500 from an importer and ended up selling the car before i could fit them, pretty keen to just get rid of em.
if ya keen mate call me on(08) 82432250
cheers nicko
Helios, these are still available, I coulda got them to Southern Sydney suburbs for you last month if you were able to collect.
Still $400 plus now $90 for postage/freight
Hey,
Still in the market for some suspension.
If you post on this thread, please be prepared to supply pictures and to reply. Please if possible let me know if the suspension will lower the ride height.
dat2kman: Please send me pictures as the photobucket of the front Trust ones has disappeared.
Cheers!
Paul
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
