Heres some items for sale
D1 Project IMAMURA RSM:
$310
Greddy Profec B Spec II Boost Controller:
$390
Apexi Turbo Timer:
new in box
$70
Pivot gauges: Vacuum, Oil temp, Oil pres
$375
Also have a Project D1 IMAMURA SAFC
no pics currently
$360
Will post other items when they are available.
If you think my price is bullshit throw me an offer then we will talk.
It doesnt hurt to try :/
https://www.sau.com.au/forums/topic/279570-random-items-melbourne/
  • Replies 43
Do you have any proof that you own these, and that they are as sight seen? Just curious as all the pictures seem to be off a Malaysian Marketplace website...
Here's the Pofec B Spec II
I bought it off him and thats why i used the same photos.
am currently in malaysia.
cheers
Heres the photo of the D1 Project IMAMURA SAFC II:
took the photos 1min ago
edited, wrong photos corrected
Edited by eskaR
the pivot gauges are gone before they leave Malaysia.
Also my mate did not manage to take the PROJECT D1 SAFC II off his car before I left, but this item will be coming on next month so lemme know if ure interested.
here are some photos taken by ME these items are the EXACT ITEMs shown @ first post.
I understand that people wanna make sure they dont get cheated
so heres some proofs that i own these
Project D1 RSM (its a limited version you know how hard it is to find one)
have a little stain on top of the console but its in good condition overall
photos on the first post were taken a day before it was taken off
Apexi Turbo Timer
brand new in box
Profec B Spec II
used but its just like a new one, off an evo 7
all PMs replied to
Apexi Turbo Timer SOLD pending payment
ProfecB spec II
Project D1 RSM
WHEELS are still up for grabs
Project D1 SAFC II will be available next month
Lemme know if your interested in the apexi turbo timer i could get some more stock in on next month.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
