Im trying to get a 96 R33 GTS series 2, but my dads bitching about it not being safe enough. It has duel airbags as all of you know but it doesn't have ABS and he's now trying to make me forget about it. Are there anyways you can put ABS on non ABS brake kits? I know its going to need a ECU and all sorts of stuff but has anyone ever done it?
https://www.sau.com.au/forums/topic/279641-abs-on-na-r33/
also tell your dad just because it doesnt have ABS doesnt make it any safer, thats how i use to think aswel, then i did level 1 & level 2 advance driving course and they teach you about thresh hold braking, in otherwords they teach you how to brake to the best of the cars ability without locking up the wheels but pulling up just as good as those cars with abs. its a good course to do regardless of what car you have and features you have. It teaches you about how the car handles in certain situations and helping to control it say something goes wrong.
https://www.sau.com.au/forums/topic/279641-abs-on-na-r33/#findComment-4721439
+1 for the advanced driving course.
My R32 has ABS - and I think I have only activated the ABS twice in the 9 years I have owned it (and one of those times was on the track). As far as I'm concerned, ABS is for idiots who don't know how to drive (as distinct from those who have a licence).
Tell your dad that ABS is not the be-all-and-end-all of a safe car - it's the nut holding the wheel that counts.
https://www.sau.com.au/forums/topic/279641-abs-on-na-r33/#findComment-4721501
Hey dude, I'm currently in the process of doing an abs install on my non ABS R33 S2. Mines a Turbo though so i'm not sure if there are any differences.
Parts needed
Front ABS Hubs with sensors and wiring
Rear ABS Diff with sensors and wiring
ABS Computer
BMC
Pump
A few extra brake lines
Not sure about the ecu. I think its just a seperate computer kinda like the hicas. Not 100% sure though. Will find out soon enough.
https://www.sau.com.au/forums/topic/279641-abs-on-na-r33/#findComment-4723189
Parts needed
ABS Computer
BMC
Pump
ow really? sweet well tell me how it goes =)
https://www.sau.com.au/forums/topic/279641-abs-on-na-r33/#findComment-4724517
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
