For sale or Trade
1989 4 Door R32 skyline
N/A RB25 manual
Good for P platers
coilover suspension
Slotted front rotors with bendix heavy duty pads
18 inch konig rims x4
16 inch stock rims x4
Plus many extras
$8000 as is
or $9000 one colour
will trade for turbo or rotary
Ph: 0431758441
Email:[email protected]
https://www.sau.com.au/forums/topic/280023-r32-4-door-rb25-na/
More of a list for you
This is type m model from japan in 2005
R33 front lower control arms
ISC N1 coilovers
F & R strut braces
RDA front slotted rotors
Bendix front pads
18 x 8 rims
Basic sterio
JJR drift handbrake button
Hicas lock bar
Urathane G Box mount
2.5 inch straight exaust with small muffler and twin 2.25 tips
Guages - oil press and water temp
GTR front end
180 sx steering wheel
R33 front drivers seat
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
