Hey all puttin my 30det into my 32
okay so the cars a 92 gtst rb20det
head is a s1 rb25de
computer is a mapped rb20 to suit
question is-
can I run the rb20det loom? I've already put the rb20 cas and ignitor on so apparently it'll plug in?
Just want to be sure,have the s1 25 loom it had on it but it's been modified too many times,31>31>s13,
so don't wanna use it.
Worse case I get a 25 loom and wire it up,but why bother if the 20 loom will work on the 25de??
Thanks in advance,
Nathan
https://www.sau.com.au/forums/topic/280109-wiring-question-r32/
rb20 silvertop loom will work for r32 rb25 non VVT head, providing you use standard injectors etc etc. Intake side sensor wise on both is the same, just your 25 intake ports are bigger on the head itself.
You have said rb25de s1 but, which still came in the R33 with VVT, this will not work.
The head must be a 25 non VVT from an r32, which I am guessing you have to dodge the vvt shit with the 30 bottom end.
Edited by James_03
it will work :blush:
my setup
R32 RB20DET
RB20DET loom, coilpacks, CAS, ignitor, knock sensors, afm, water temp sensor - all running off RB20 computer
RB25DE VCT S1 head, plenum, manifold, vct disabled. TPS, AAC, side feed RB25 injectors
other mods, 800cc injectors Z32afm HX35 turbo external wastegate.
everything runs perfectly, cuttently making 314rwkw and it drives like factory of the remapped RB20 ecu.
pm me if you need any help!
cheers!
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
