Hey all puttin my 30det into my 32
okay so the cars a 92 gtst rb20det
head is a s1 rb25de
computer is a mapped rb20 to suit
question is-
can I run the rb20det loom? I've already put the rb20 cas and ignitor on so apparently it'll plug in?
Just want to be sure,have the s1 25 loom it had on it but it's been modified too many times,31>31>s13,
so don't wanna use it.
Worse case I get a 25 loom and wire it up,but why bother if the 20 loom will work on the 25de??
Thanks in advance,
Nathan
https://www.sau.com.au/forums/topic/280109-wiring-question-r32/
rb20 silvertop loom will work for r32 rb25 non VVT head, providing you use standard injectors etc etc. Intake side sensor wise on both is the same, just your 25 intake ports are bigger on the head itself.
You have said rb25de s1 but, which still came in the R33 with VVT, this will not work.
The head must be a 25 non VVT from an r32, which I am guessing you have to dodge the vvt shit with the 30 bottom end.
Edited by James_03
it will work :blush:
my setup
R32 RB20DET
RB20DET loom, coilpacks, CAS, ignitor, knock sensors, afm, water temp sensor - all running off RB20 computer
RB25DE VCT S1 head, plenum, manifold, vct disabled. TPS, AAC, side feed RB25 injectors
other mods, 800cc injectors Z32afm HX35 turbo external wastegate.
everything runs perfectly, cuttently making 314rwkw and it drives like factory of the remapped RB20 ecu.
pm me if you need any help!
cheers!
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
