Just finished putting my new headlights in and when i turn the lights on....my indicators come on..and stay on =/ ...
then when i indicate the side and rear ones flash really fast and the front ones still just stay on?
anyone know whats goin on there lol?
thanks :D
https://www.sau.com.au/forums/topic/280138-indicators-stuck-on/
Generally when indicators flash fast it means that one or possibly more indicator lights are not working or plugged in correctly so dont worry about the ones flashing fast (as you know its the front indicator lights that aren't working)
You may have a fault with the way you've plugged in the new headlights or somethings gone faulty with the indicator relay (which would seem a bit coincidental)
You might be able to just call up your local sparky who can offer you better advice :D
Ive put in a new set of headlights coz i cracked my old ones (also have new bulbs and threw old ones out)
the headlights themselves work fine on both high and low beam.
its just the indicators that are giving me hassles.
With hazard lights all work except the front ones.
Ive tried disconnecting and reconnecting them, ive also tried using the plugs from the only set with the new bulbs
and no success.
nope..havent tried to rewire anything ...
I'll check the fuses when i get home and where would i find the earthing wire?
cheers :D
ok..so i was fidling around tonight....and i just realized...that the indicators only work when the hazard lights are used (minus the front ones which only come on..and stay on solid....when i turn the lights on)
when i sit in the car and indicate nothing happens on the dash and nothing happens outside...except for the front ones staying on ... :)
the earths are connected......i checked the starter indicator and the turn signal fuses and they were ok.
ideas ppl...throw em at me....
atm all i can think of doing is getting 2 gingys and hiding em under the hood and when i indicate it jabs em and they poke there head outside..... -_-
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
