R33 series 1 headlights – both in perfect working order – all clips and brackets in tact – drivers side light has crazing on lense - $400 ono
4 x Koya Drifteks 17x8 and 17x9 GTST offset (+38 I think, will confirm) with Federal RS595 semi slicks – approx 60% left on all tyres - $1000 ono
Starcorp Impuls 18x8.5 and 18x9.5 +38 offset, deep dish rear – Federal SS595 on rear 255/40/18 80% tread, Nexen N300 front 235/40/18 70% tread - $1000 ono
Z32 AFM – good condition – might have a plug somewhere - $200 ono
Apexi pod filter – fair condition - $50 ono
Drift brand oil catch can – blue in colour - $40
R33 series 1.5 airbag steering wheel – very good condition - $150
R33 GTST stock fuel pressure regulator - $20
R33 GTST turbo elbow and gasket - $50
PM, Post or phone/text 0414249292
More items and pics to follow when I get time
https://www.sau.com.au/forums/topic/280295-r33-and-various-parts-for-sale/
Extra info:
Drikteks are bronze
Starcorps are white
most have some rash
located in Ipswich QLD
more stuff:
R33 GTR front strut brace - $100
R33 GTST crossover pipe and all engine side cooler piping with BOV return - $100
R33 GTST turbo inlet flexi pipe (turbo to AFM) - $30
Greddy Profec A EBC - controller and solenoid with loom ends, needs loom made to connect the two, would be an easy job for anyone with minimal soldering skills - $100 ono
R33 GTST turbo heat shield - $50
painisgame - dont have reverse sensor switch, PM SAU user "FineLine" - he may have what you need
Drifteks sold
Starcorps no longer for sale
will take reasonable offers on remaining parts
I probably do, I'll have a look when it sells
It is currently listed on eBay and has a bit so anyone interested will have to purchase via eBay
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
