if any of you have read the max car performance thread you know that i got ripped off by some guy named matthew dillon. im posting up again to ask a few more questions. does australia have anything like the better business bureau? you know some organization i could turn to to help me clear this up. would the cops do anything about it? if so could somebody give me the phone number of a local station? $1000us is a lot of cash and i really cant afford to just give up on it. if worse comes to worse im going to fly down there and find this dude. any help you all could give me would be greatly appreciated.
thanks guys
clay
https://www.sau.com.au/forums/topic/28033-honest-business/
Clay,
Each state in Australia has a Dept of Fair Trading (Queensland) or similar names in other states. Which state did this villian Dillon supposedly reside in?
Let us know and I am sure that someone will be able to give you the contact details or you could search under each State governments web-sites for the relevent department. Failing all that try our Federal Police.
Don't give up mate as worms like this give scrupulous traders a bad name.
Cheers
Murray
https://www.sau.com.au/forums/topic/28033-honest-business/#findComment-583561
Refer to the thread below in regards to information on Maximum Car Performance.
http://www.skylinesaustralia.com/forums/sh...&threadid=26793
The local police stations around the area are:
  • Runaway Bay - Morala Ave 4216 (07) 5537 5099 (probably the closest to Labrador)
    Surfers Paradise - 68 Ferny Ave 4217 (07) 5570 7888
    Southport - 96 Scarborough St 4215 (07) 5571 4222
To dial this = international access number + 61 + 07 + 5537 5099
https://www.sau.com.au/forums/topic/28033-honest-business/#findComment-584439
maybe try the ACCC, they deal in this sort of dodgy stuff, but worst comes to worst, call a guy up called 'Ray Martin' he has a show called A current affair, and it shows dodgy buisness men all the time, harrasses them, and they give your moeny back instead of being on tv as being dodgy.
https://www.sau.com.au/forums/topic/28033-honest-business/#findComment-585824
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
