Just been back from the EPA, and with the boost almost stock it still turned out 92db instead of the approved 90db. He would not pass it and i don't consider my car loud.
So i need to take 2db off it, so whats my best options??
I might replace the 3 inch cat with the standard 2.5 inch cat and try and turn the boost down even further, would this do it?
https://www.sau.com.au/forums/topic/28036-failed-epa-by-2db/
dang.. if its nearly at stock boost levels there probably isn't much else you can do to reduce it further by playing with the boost. You could try and make it spool up very late, so its making maximum boost later on, and hence less noise down low.
Did you put the standard box back on? if anything you want to restrict the airflow the best you can, generally the opposite you'd usually want to do.
Stock cat should be a bit quieter, but might not get you under. I passed with full 3" hi-flow cat, but i think mine was a bit of a freak passing with absolutely no exhaust modifications.
Do you have a resonator in there? (its like a bulge you might see in the pipe). Bends in the pipework i think also tend to reduce the noise a bit.
Otherwise its time to borrow a stock exhaust off somebody.
https://www.sau.com.au/forums/topic/28036-failed-epa-by-2db/#findComment-583572
THat's farcked!!! Go and ask them how do you know your machine is not farked!!!
ask them to test on other machine...
2db come on that;s nothing compare to harley davison Bikes.
https://www.sau.com.au/forums/topic/28036-failed-epa-by-2db/#findComment-584431
This story sounds familiar.
I got done for 2dB over the limit nearly 18 months ago now. I fixed it by adding another resonator under the car. Originally I had a hotdog style resonator and barrel type s/s muffler at the back of my 3" system and recorded 92dB. Had another box type resonator installed inline with the hotdog and it brought the reading down to 89dB, just enough to get the EPA off my back.
As long as you use straight through type mufflers and resonators you shouldn't loose too much power, but honestly, I wish I had just borrowed a standard exhaust for the test. It would have saved cutting up a perfectly good exhaust.
Z.
https://www.sau.com.au/forums/topic/28036-failed-epa-by-2db/#findComment-585786
OK, if you go the steel wool, good luck. I tried this on rumour and all I managed to do was shoot flaming pieces of steel wool out of the exhaust - was pretty funny actually.
If you have the standard Jap type muffler - sounds like you have an N1 type or similar, most will have a small hole right near the tip at the bottom. This is so you can attach a muffler to the exhaust 'for street use', as a loud exhaust should only be used on the track:)
Autobahn sell the muffler inserts.
https://www.sau.com.au/forums/topic/28036-failed-epa-by-2db/#findComment-586446
CrazyGTR is spot on, get a piece of thin sheetmetal and put a single smallish hole in the middle, maybe 15mm diameter and put this between the cat and the pipe flange.
If you are clever, it will not be seen, especially if you spray it with black muffler paint around the bright cut edge, before you fit it .
https://www.sau.com.au/forums/topic/28036-failed-epa-by-2db/#findComment-586979
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
