If its a series 3 front end, e.g the sloping lights, not the early pintara style one, then:
I want the filler panel that goes under the lights/above the bumper on the front.
I'll give you $75 plus whatever it costs to pack and ship it to me.
PM ME OR EMAIL ME!!! [email protected]
rockysilvia: yes dunno if they will fit i think so
stu_r30:see what else i can sell first but make me an offer
floody:dunno will check its 88 so if thats any help
Aquaduck:not selling wheels
ido09s:dont have pics may be able to get some depends how keen you are and what you offer me only really needs a diff and to be put back together to be regoed make me an pffer and we will go from there
Is it the twincam, turbo or both?
What colour is the interior?
What options has it got?
I am interested in all the glass, badges, front struts & brakes (if twincam turbo) and wing mirrors.
How much would you be after?
Please PM me, i may be very interested in more parts!:P
