Hi my Hicas light has come on when i went to start the car one morning and has not turned off since.
I have tried so many times to get into the Hicas diagostic mode after 50+ attemps i still
cant get it to go into diagostic mode. I have checked all the electrical connections at the rear hicas unit
behind the diff also fuses etc. I have not changed anything on the car prior to the light turning on.
any suggestions would be very helpfull thanks Sam...........
https://www.sau.com.au/forums/topic/280541-r33-gtst-hicas-light/
power steering fluid?
i've got a lock bar, so the light is on all the time...meh
but if you dont and its effecting your steering there are a couple threads around about this.
Hi the steering is not affected bin any way anmd the hicas are electric type and the vehical is a series 1 skyline
could the steering positioning mechanism behind the steering wheel stopping me from entering diagnostic mode as i
would like to fix the problem not just ignore the light thanks
you should probe the hicas connector to check it is getting power and ground.
