Thanks mate ill give it a go, worst case scenario i will have to take it to Nissan. Spoke to a nissan representative and they can fix it by hooking it up to the computer and tuning it. Can you believe they charge $122 per hour.
Why don't you just do the procedure documented earlier in this thread. Idle air learning, throttle position etc.
It is really east to do and if all other things on the car are ok the car will set the idle at 650rpm (+-50). If idle is not set between 600-700 the ECU will not memorize the idle setting and idle will be moving around.
I had a faulty PCV valve and this stopped the idle being set correctly.
Good luck and save your self $100 for better mods.
Ohh talking about draining batteries has anyone seen those articles on the infiniti forums about our bose radio systems drawing enough energy to drain the battery over a period of 4 days? Apparently what happens is even when the system is manually turned off with the car turned off the radio draws energy from the battery. I can't remember exactly what the thread said but it was either related to a fault in the headunit itself or the amplifier located in the boot. I wouldn't mind looking into this as it can be tested to see whether the radio is drawing a certain amount of energy by hooking a meter up to the fuse box where indicated "radio" is that right Chris?
when i finished the install i reconnected the battery and i did an ecu reset straight away before i even started the car again
the car started fine and i took it for a 20min test drive for the ecu to start learning again. i got home and parked the car. i had to move the car again after 5 min and when i started the car - stall.
i think the instructions state the car should be at operating temperature when performing this procedure. rekon that might have something to do with it?
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
