Thanks Scott..yeah I LOVE the yellow... I know its not for everyone but I have a bit of a fetish haha
Yeah I'd love to put her in a dyno day - she's only running stock power so it wouldn't be too exciting but meh! :O
HAHAHA
I've had no problems with mine, i haven't noticed anything so it must be normal... Sure you're not trying to put deisel in it are ya shell? LMAO
yeah good call on the Nismo kit
What, they don't use diesel? :rofl:
Are you going to get different rims and clear front/side indicators? I don't know how the indicators would look on a yellow car but definitely a must for black and silver skylines. Thing i really don't like is that most r34's the rear part looks really bad most of the time as the body kit seems to go over the rear wheel (kind of like those lancers with body kits). Do you just get heaps of wheel offset and stretched tires to counter that.
I'd love some black rims... reckon they'd look hot on the yellow
have also been 'told' I need some works XD9s :P
haven't even thought about the indicators to be honest! I think you're right, on other colours it looks heaps better, but I don't think its as noticable on the yellow
