Originally posted by Ryan D
R33 GTS4
2.5l, non turbo, all wheel drive, and sexy as hell.
cant go wrong
Yeah thats what i had heard the 2.5 in a 32 is lethal where as in the 33 its powerful but is held back by weight ratios.
But i dunno im just a kid, lol, keep the opionions coming
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-585825
The fastest N/A's down the strip I know of are actually the R32 GTS25's, they come out factory with 142kw at the flywheel. With a bit of work they can run low 15's.
Even though the type S R33 tend to make a little bit more power(147), the extra weight of the R33 works against them.
But give me a R33 any day :P
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-585957
umm people are already buying them and putting them in storage in japan. when the car is 15 years old to the day u can bring it in, but make sure u research its not that simple, u need to apply for permission to import that vehicle and a whole range of other things.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-586053
Let a company like prestige motorsport worry bout all that for you if you choose to import, i got the R32 gts25, its a nice car, my auto box holds it back but thats to change in the future. Got the 2.5ltr goodness and the lighter shell, more room in a r33, bigger backseat etc, more spacious, but the r32 just looks mean and ready to go.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-586065
The R33 GTS25 is quicker than the R32 GTS.
Last year at the drags a guy with a R32 2LGTS manual was running high 16,s for the 1/4 mile, that was with air filter,extractors and 2 1/4" exhaust. A R33 GTS25 will run high 16's stock.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-587424
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
