Hey All,
I have all these parts that I no longer require and have decided to sell them off! I'm located in Adelaide but am willing to post
interstate at buyers expense. All the parts have come from a 33 vspec GTR and 32GTR and are all in great working order and
not damaged in any way. The parts themselves are used but as above in great working order. If you are interested in any of
the parts feel free to send me a PM.
R33 centre grille -$100 (off gts-t)
R33 N1 front bar -$200 (off gts-t)
Harmonic balancer (32GTR) -$50
R33 alternator -$80
AAC valve and air chamber (X2) -$100
RB26 stock fuel rail + reg (X2) -$30 ea
Intake manifold assay (injector plate) -$250
RB26 throttle bodies + linkages -$250
RB26 440 injectors X6 (R33) -$250
4WD sump,baffles and gears -$300
Rods and pistons (2 pistons have ring land failure) -$100
R33 Vspec turbos 024U dumps,heat shields, exhaust manifolds and O2 sensors -$500 pair
R32 05U turbos with as above -$300 pair
Front cover baking plate -$50
Idle control valve -$80
TPS (throttle position sensor) -$100
Autometer oil pressure guage (psi) -$30
Splitfire boost guage (psi) -$20
Exhaust manifold heat shields + dump heat shields -$20 the lot
Y twin connecting pipe -$30
Air flow meters (X2) red label - $200 the pair
th_08022009265.jpgth_08022009270.jpgth_08022009271.jpgth_08022009272.jpgth_08022009275.jpgth_08022009276.jpgth_08022009278.jpgth_08022009282.jpgth_07122009210.jpgth_08022009283.jpgth_06282009154.jpgth_08022009284.jpgth_06282009152.jpgth_08022009286.jpgth_06282009172.jpgth_08022009287.jpgth_06282009173.jpgth_08022009288.jpgth_05302009098.jpgth_08022009289.jpgth_05302009105.jpgth_rb26parts033.jpgth_rb26parts028.jpgCheers HULI
https://www.sau.com.au/forums/topic/281569-rb26-engine-parts-sale/
hey mate interested in 33 n1 front bar off gtst and r32 turbos what do you think fraight to central coast nsw will be. pm me of contact me on 0411672105
Hey All,
R33 alternator -$80
AAC valve and air chamber (X2) -$100 *****(1 REMAINING)****
TPS (throttle position sensor) -$100 ****SOLD****
Hey All,
R33 alternator -$80
AAC valve and air chamber (X2) -$100 ****1 SOLD/1 REMAINING****
Front cover baking plate -$50 ****SOLD****
Exhaust manifolds, heat shields + dump heat shields -$20 the lot ****EXHAUST MANIFOLDS SOLD****HEAT SHIELDS LEFT
IF YOU WANT TO MAKE A REASONABLE OFFER ON THIS STUFF THEN DO SO, BUT THOSE WHO ARE TIME WASTING WONT BE REPLIED TO AT ALL!!!
CHEERS HULI
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
