  • Replies 40
nothin to do with handbrake.
if engine is turning/running... once nav is on, the magic button refuses to turn it back off....
magic button only works when engine is off, or when I turn off the engine and restart it again (in magic button off position)
and don't touch it...
ok thats weird. I took that car down eastlink with it on and off and it behaved. pop past on sat and we'll go fro a drive. actaully I'll all you in the morn.
it works on and off while driving with the other trip computer screen/ original jap nav...
but not on the tv tuner... once it's on, it refuses to switch back to the tuner. the only way to get the tv tuner back is to turn off / on engine to reset it.
wish u could tell me 'cut the yellow wire' thing that'll save me a trip down... LOL
sat might be difficult, i need to look after the kid while wife's away.
the V35's ciggy lighter might be too deep for it, or it just need to turn sideways at an awkward angle...
upon further search I found even more weird stuffs.. some looks like one of those StarTrek USS entrprise space ship...
I can't help but laughing at the shape of this. must be a star trek fan who design it.
an example of Chris' work on my car...
this is not a setup for the faint hearted IMHO...
trying to make the Nav to work on top of JDM trip computer, TV tuner, and the reverse camera!
had a few hair pulling moments to get it right but Chris finally cracked it!
good job Chris...
http://www.youtube.com/watch?v=pGyiOfF2z8s
thank you!!!!!!
the issue you had I had a GOOD think about. turns out that we were latching that relay on . when I pulled it the latch broke. hence my fix.
the video is now going to be used on my site as a demo for these cars. (I'm taking a copy as well in case you remove it.)
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
