nope - its meant to be off... only comes on if theres a problem with atessa ( the 4wd system of the car ) could be things like low fluid in the resovior ( found in the boot on the right handside behind the carpet) or even things like uneven wheels ie commo spec - if you have stocks on the back and big rims on the front, but basiclly if the light is on, atessa is off..... get it checked out. can also be some electrical faults with it aswell, theres lots of things....
Adam
https://www.sau.com.au/forums/topic/281754-awd-light/#findComment-4747295
were can i find the codes, ive seen then on here somewere, cant remember tho
You can always take it to nissan and plug in the consult. I know Hornsby nissan have a consult there.
If you are out in Camden way my mate has a shop with one too.
If you are out in campbelltown way I have the laptop and nissan datascan.
If that fails. Try doing a search "self diagnostics"
https://www.sau.com.au/forums/topic/281754-awd-light/#findComment-4748071
did "they" give you a 2 year warranty or did u get one of those rip off warranties from a third party that most importers offer, where u have to pay for services like every 5,000km from a legit mechanic and it only covers a certain amount for each part of the car?
https://www.sau.com.au/forums/topic/281754-awd-light/#findComment-4749475
haha not sure, they have there own mechaincs at the import dealership. so not third party
https://www.sau.com.au/forums/topic/281754-awd-light/#findComment-4751925
The import dealership are usually poorly equipped. Honestly sounds dumb but make sure they dont pull the bulb out.
If no succcess I say take it to nissan who will hook up the consult.
I had 4wd light come on my r33 GTR in the early days. I lost 4wd when it did. We tried alot of things. You know what? took it to nissan and they hooked up the consult and it turned out to be the TPS!
https://www.sau.com.au/forums/topic/281754-awd-light/#findComment-4752139
Just took it into my mechanic as a pre chek before i take it to the importers, he had the generic jap diagnosis for it and it jsut came up with a problem with the ABS, which he thinks could be throwing out the AWD sensors.
Now have to wait and see what the importers mechanic say.
Edited by sydking
https://www.sau.com.au/forums/topic/281754-awd-light/#findComment-4762964
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
