Hrm.. I dont reallt hink thats legal, unless you own a copy and its for backup purposes :cool:
However I think it works much the same way, you need to have your ps2 chipped or a boot cd, and need a DVD-R, as PS2 Uses DVD's.
But, as I stated before, its not very legal, unless you own the original.
https://www.sau.com.au/forums/topic/2819-playstation-2/#findComment-50028
Guest Static
The process you are looking into is called DVD Ripping.
It's when you cut a DVD sized disc (up to 4.7gb) down to a 700Mb CD. To do this you need to either remove or downsample the large movie files in order to reduce the total size.
There are tutorials on the net, try http://www.Megagames.com. You will also need a couple of tools.
Each game has a completely different method of ripping, there is no generic 'rip-dvd-to-cd' app ... yet.
You need;
A) A DVD reader
B) A ModChip
C) Patience
Nb. It's not worth the hassle.
Get yourself a mod chip from http://www.theModShop.com
and get your games already done from these guys http://deliveryman.gameday.de
https://www.sau.com.au/forums/topic/2819-playstation-2/#findComment-51281
Guest Static
I manage the Mod Shop in Belmon (Perth, WA)(http://www.themodshop.com). I'm running a couple of specials at the moment.
Godzilla mod $100 (norm $150) - limited mod - requires a boot cd
Detonator mod $200 (norm $250) - good mod, plays DVDR & CDR - requires a boot cd
Raptor $300 (norm $400) - THA 5HIT! plays all games PS1 & PS2, no need for any boot cd. Plays copies like they were originals.
Check the web site for mod specs
~ Static
https://www.sau.com.au/forums/topic/2819-playstation-2/#findComment-51294
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
