Wrecking R33 GTST Series 1
Body Panels not for sale except driver's side guard (gun metal)
All mechanical parts in good working condition.
Everything for sale.
Gearbox (filled with Redline Light Weight Shockproof gear oil)
Tailshaft
Factory BOV
Diff
Radiator
Motor
AFM
Brakes
Arms
Exhaust
Floor Mats
Etc.
All mechanical parts in perfect working condition. Ask me if you want anything in particular.
Aftermarket bits:
HKS BOV with RB25 adaptor
Autogauge Boost Gauge (Stepper motor series)
3inch Bell Mouth Dump Pipe (bolts on to standard RB25 turbo)
3inch Stainless Cat Back Exhaust
Bilstein shocks travelled 2000kms (Sydneykid set up)
Exedy Heavy Duty Clutch Plate with Custom Built Pressure Plate used less than 3000kms (1.1 ton Clamping force)
Ikeya Formula Caster Rods with rubber bushes used less than 2000kms
Yellow Jacket Coil Packs almost new (bought 1month ago, used less than 1000kms)
Turbo Tech Boost Controller
KNN Pod Filter
GK Tech Deep Dish Steering Wheel (used less than 5000kms)
R33 Dash Mat
Cusco Front Strut Brace
Bride Copy Seats
Volk TE37 17inch (8.5 x 30 front) (9.5 x 35 rear)
Sits flush on R33 guards. Comes with Federal 595RS semi slicks (235/45 80%tread front) and Continental ContactSport2 (245/45 rear 50% tread)
Rays light weight lock nuts (Gun metal colour)
R34 GTR Standard Rear Sway Bar 24mm (comes with bushes) fits straight onto R33
UAS Brake Master Cylinder Stopper (like new)
Everything located in Sydney.
If there's anything you're after in particular, just ask me!
Contact me at 0433 712 092. Call / sms anytime, anyday.
Edited by bin
https://www.sau.com.au/forums/topic/282538-wrecking-r33-gtst-series-1/
  • Replies 48
PMs replied.
Forgot to add that there's also a standard computer which has been remapped by Toshi on the forums.
Tuned for : Pod filter, 3inch exhaust, Front mount intercooler, 10psi boost.
how much for the cusco front sway bar? got a pic of it?
you sellin the dash cluster? how many kms on it?
how much for the remap ecu?
where u located?
thanks
Its not a sway bar. Its a strut brace. Asking $90. Don't have pics at the moment will upload asap but I'm sure we all know what a strut bar looks like.
Cluster is for sale. 137xxxx kms on it. Asking $110.
Toshi Remap ECU $400.
All parts located in Kogarah, Sydney.
how much for rear brake assembley?
thanks
Would actually prefer to sell the whole front / rear 5stud assembly together. If some one is willing to take the front, I'll let the rear go for $280.
Alright guys asking for pics, I'll try and get them up asap. Car is at the workshop now so I gotta find time to go down and get pics.
Anyway, I'll put up prices for the more popular items.
Full RB25 motor with turbo - $1900
Gearbox - $1100
Front Strut Brace- $90
Yellow Jacket Coil Packs - $300
TE37s - $1300
Bilsteins- $900
Full front/rear 5stud assembly with brakes and rotors - $650
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
