So i set out saturday morning to replace the exhaust manifold gasket on saturday
long story short, someone before has tightened up all the nuts so tight it's began to shear the thread in head, so i have some along to tighen up the nuts again and shear them all more
so pretty much my only option is to tap the holes bigger to 12mm, never done any hole tapping before especially not in awkward positions like that
i've heard of mobile guys that do this etc
anyone had it done, if so who did they get to do it? exhaust shop or mobile guy
did you tap the holes yourself?
https://www.sau.com.au/forums/topic/282684-exhaust-stud-hole-issues/
Dude,
Save yourself a lot of pontential grief and get a mobile guy to do it. If it is in a hard spot they can be easy to get wrong then you have a bigger problem. The mobile guys have all the good tools as well...Also dont try and start it yourself because inserts like helicoils have non standard size drills and taps...
Its always good to learn so you can do it yourself but learn on something thats less critical, cheaper and has easy access..
yeah thats how i was leaning
might do some ringing around
it really gives me the shits that proper mechanics can't even do shit properly, it's no wonder i do all my work myself
the nuts had obviously been tightened way too much last time (head was removed and repaired almost 2 years ago), to the point they had already started to come out of the head on some of them. there is heaps of evidence that it's been leaking all around like 5 of the cylinders under the non-genuine gasket they used
Edited by mystery_kid
I had this problem once before,tried using easy out's to remove the snapped bolts got all except one frikken bolt.Which led to me having to take the whole head off and taking it into a mechanic.
I then had to buy a new head gasket and a set of head bolts all for one stubborn bolt!!! :banana:
adis that was my plan originally, i'd bought studs but nissan they gave me the wrong ones apparently they gave me studs for the turbo -> manifold, which i didn't realise until the day
which is mostly my fault as i asked for exhaust manifold studs meaning head studs, but at the same time the guy was like 'do you want a full set of 12?'
not that it would have mattered anyway, threads were already pretty f**ked before i even got to it
anyway got a guy coming out next week, $180 to helicoil all 12 of them and he's organising some new studs + nuts
Just thought I would give you a couple more tips.....Last manifold I put on still going strong at 60,000km.
1. Make sure exhaust manifold is not deformed or warped. Check that all flange faces are flat by placing a steel ruler or straight edge along face that bolts to head. If it is warped it will always break the stud and end up leaking.
2. Always use Nissan genuine gasket. Worth the $120.
3. Always use new nuts. Use steel or inconel (spelling??). Never ever ever use brass. (I had a guy working at Peps once tell me brass nuts were ok to use.)
4. If a stud looks just a little bit suss, replace it. You are anyway.
5. Always use correct tightening sequence. This is in the workshop manual. Generally you tighten from centre of manifold outwards. Try and get good even tension in all nuts and do it in 2-3 passes.
6. Always use a good ring spanner. Never use a cheapy!!
7. Always use heaps of anti seize.
8. Never try and rush it...
9. Have your first beer AFTER its done....
cheers
i want my beer now :\
yeah my issue wasn't broken studs, it was just not done properly last time to sum it all up
non-genuine gasket, tightened up too tightly so it just began to shear the threads off
when i first noticed it was making the ticking sound i found where it was coming from on cylinder 1 and the top nut there was finger loose. when i finally got around to fixing it properly 3 other nuts on that end were all finger loose.
thanks for the tips
Oh and 3 more tips...
1. Never ever use a bolt in place of a stud +nut. Studs are better because you get full thread engagement in the hole plus when you are tightening a nut on studs the sliding surfaces are steel-steel as opposed to steel-alloy.
2. When you put the new studs in but before you place the manifold over them, measure the length of the non-threaded or blank section on the stud. Make sure that this length is at least 1-2mm shorter than the thickness of the manifold flange. Some studs have a longer blank section and if the nut bottoms out or runs out of thread before it bears hard on the flange, its the same as a loose nut. Its been done before...
3. Make sure you re-tension the nuts after say 500kms then every 20,000km. Its a pain to do but worth it...The gasket compresses a small amount over time...
cheers
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
