  • Replies 48
48,000km? do u have paper work to prove it hasnt been clocked? looks clean though
whats the reason for selling if i can ask?
cheers
i dont have any of the japanese paperwork, but i think its accurate. although there is a few small scratches on the outside the inside is like new.
selling a few cars i own for less then retail to buy a time attack track car in japan.
Great price for Genuine RZ. Genuine RZ have Recaro and Big Brakes from factory, along with the 17" wheels, whats rare I spotted is teh Cruise. VERY rare on a JDM JZA80 Manual.
Racing steering wheel was removed for compliance, along with the front mount intercooler, braided brake lines, HKS pod filter, aftermarket exhaust. so it is very very very factroy
  • 3 weeks later...
