Who is everyone insured with, that 1) insures imports, 2) doesnt require the car to be garaged, 3) has pay by the month as an option.
I've been looking around everywhere but apart from Shannons, everyone else who does pay by the month won't touch imports (wah wah wah, parts are too expensive to get wah wah wah bs bs bs).
I was insured with Shannons previously, but they won't insure me since I moved to Tassie (not comprehensively anyway) due to the fact my car is no longer garaged. Which sucks, but oh well.
I did have a quote from Famous Insurance, however since then they've decided to get rid of their Pay by the Month option (wtf).
If anyone can help me out, it'd be great.
Cheers,
-- Cyph
https://www.sau.com.au/forums/topic/283097-insurance/
Does Just Car offer pay by the month insurance?
home_title_line.gifshim.gif You may be eligible to pay for your policy in regular instalments by direct debit. We will tell you if you are eligible. When you pay this way, the total premium is higher than we charge for one annual payment, reflecting the higher costs we experience.
Question still not answered? See below or please ask a Just Car Insurance operator.
https://www.sau.com.au/forums/topic/283097-insurance/#findComment-4765735
yeah i spoke to them today, and they told me i need to be 1 year full comp to get month by month :D even though been with them for 2 years on 3rd party, sucked.. looking at building a garage beside the house so shannons can insure me, can cover my car for a lot more if i can...
https://www.sau.com.au/forums/topic/283097-insurance/#findComment-4766924
yeah i spoke to them today, and they told me i need to be 1 year full comp to get month by month :( even though been with them for 2 years on 3rd party, sucked.. looking at building a garage beside the house so shannons can insure me, can cover my car for a lot more if i can...
just car is about the cheapest tho
but apparently a pain if you ever want to claim
surely a small loan for the amount of the premium would similar to what you would pay for pay by the month?
https://www.sau.com.au/forums/topic/283097-insurance/#findComment-4769817
I had the same problem with my car. It is real hard to get into garage so have to park it in my carport which lucky its a 4 car one and not visible form street. I had to go to just cars for insurance. Had to pay first year up front then after that you can pay by the month and a few extra dollars. Have heard some bad reports about them but will see. Was with them for my other car but changed to shannons because they are cheaper and have an office here
https://www.sau.com.au/forums/topic/283097-insurance/#findComment-4771934
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
