hey all.. as above i have a FULL set of black dteks 17x8 +34 17x9+35 9 hole
with 225/45 potenza, nb stretch on rears, and ok thread on front , rears are kinda gone, see pics
located vic 3037
pik up only atm...
looking for about 1400 coins since there pritty good condition (negotiable)
* these will fill stock 32/s13/ 33 gaurds well, my 32 rears scrubbed so i rolled em. front was flush with guards.. and questions ask :)
0411 294 024 shaun call any time :blush:
Edited by shaunpierre
https://www.sau.com.au/forums/topic/283588-fullset-of-black-drifteks-nuts/
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
