I have the following is for sale:
RB26 Carbon fibre timing belt cover / coil pack cover - $300
Trust Clear Timing Belt Cover never used - $150
R32GTR STD swaybars front and rear $150
R32GTR aircon complete from firewall forward (Lines, compressor + bracket, receiver dryer, condensor+fan etc) removed due to car for track only now. All fine and working on removal, no leaks and retrofitted for the new gas $150
Nismo bootlip - original rubber one, has a bit of damage and rust around the underside and mount, but ultimately fixable if you want to spend the time. I upgraded to a carbon one. $50
4 x Yokohama Advan Sport V103 255x40x17 virtually brand new - +90% trend left. Paid over $1600. - $1000
18mm MDF subbox to fit in boot of R32. Box built to house 2 x 12inch subs, and will also fit under rear strut brace if you have one. just needs carpet - Box only $50
Also Specialized MTB - 2004 Hard Rock Sport with disc brakes, RST front suspension, Top Peak digital Speedo etc, Excellent condition barely ridden New $1600 - $500
Items located in Adelaide - postage available at buyers expense
pic of the nismo bootlip plz, wot sort of damage on the underside?
Pics attached - there is a little damage to the metal strengthening inside the wing, but overall it is in pretty good condition.
hey mate, is it just the sway bars front and rear or are some of the mounts included?
thanks
U bush and end brackets are included on the rear bar, the front has bar and U bush only. - see pics enclosed
interested in the sub box,does it push all the way back to the rear seats?does it fit under the rear window wiper?
Certainly does fit in the boot right up to the seat - also has provisions for the strut brace to fit as well. See pic below
Specialized MTB - 2004 Hard Rock Sport with disc brakes, RST front suspension, Top Peak digital Speedo etc, Excellent condition barely ridden New $1600 - $500 SOLD
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
