In September? maybe the 19th which is a Saturday?
Could go down to Apollo Bay and stop along the way at various points like Anglesea and Lorne for food and drinks?
We could meet down the back of Salmon Street in Port Melbourne in one of the big car parks... depending on numbers...
Edited by macdog
Traffic out that way is shit... I am in workload/energy dependant :)
HAHA
I'm easy mate, where do you reckon we should go then?
I mean if we meet at about 7:30am-8:00am in the morning the traffic shouldn't be too bad...?
It'd be a good drive, we'd go the along the new freeway and bypass Geelong then go through the back way to Anglesea and then some good corners around to Lorne?
HAHA
Only good drive out there is the back way through Forrest through the Otways, the GOR is just full of Tourists and speed cameras... The weather is improving, a BBQ cruise could be done.... I'm just not a fan of the GOR, but if enough people want to run it i will come haha
+1
Nice road to drive, but for the majority of it you will be traveling at ~40kph :D
Depends what you want. Scenery or Driving Roads?
that date doesnt work for me, aiming for calder the day after in the 32...
AUGUST
29 Sat - SAU Vic Track Club Championship - Haunted Hills (Morwell)
SEPTEMBER
20 Sun - SAU Vic Track Club Championship - Calder
OCTOBER
10 Sat - SAU Vic Track Club Championship - Winton
NOVEMBER
7 Sat - MiColor SAU Vic DECA @ Shepparton
