I have posted in the Power FC forum but hoping someone can help me here. So far I have added timing to most of the cells in the 7x7 range and have to say it has transformed the way the car drives.
Now I have reduced the values for cold starting in "cranking" of the setting mode and this has made a small difference. Starts a little easier but more importantly so much crisper when warming up. Is this the way to go ? Or should I trim in water correction ?
Also, when I accelerate hard at any revs I get a lot of unburned fuel like I mean seriously a big cloud of black smoke. My two favorite tuners reckon it is the Nismo injectors but I strongly suspect "accel" pump needs trimming but as there are two columns I don't know where to start. Anybody help ? :cool:
Edited by skylinecouple
https://www.sau.com.au/forums/topic/283978-power-fc/
You have the ability to alter what level of fuel enrichment is applied during cranking, and then post-cranking when the engine has fired.
It is interesting to see how changing some values by a small amount can make a big difference, particularly in those areas where you get generally colder ambients of a morning. Increasing ignition dwell time down in the cranking zone is another way of getting a stronger start.
I have a couple of files that may help - check email :D
Regarding the fuel burn, it would be useful to log the AFR on accel, and deduce if it's in the accel settings, or fuel map.
https://www.sau.com.au/forums/topic/283978-power-fc/#findComment-4774960
Thanks Dale, I really want to nail this tune. Honestly, I thought all this time it was running great till I saw there was zero knock anywhere under 3,000rpm. I have a highest reading of 9 knock revving to 7,000rpm. That;s disgusting. I'm hoping when I get to the higher revs with more timing it may cure the dreaded black smoke syndrome. I doubt it but there is always hope.
But is accessing the cranking zone and reducing the injectors from say, 26ms to 18ms the right way to lean out the mixture during cold start? Should I be doing it in the water temp correction area instead ?
https://www.sau.com.au/forums/topic/283978-power-fc/#findComment-4775204
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
