  • Replies 121
hey id like to purchase 4 x 235/45/r17's. im from melb also but on the other side and cant make my way up there to get you guys to fit them so i was wondering if you can post them and how i go about sending you guys the money.
my postcode is 3429.
thanks.
scott.
thanks.
scott.
just sent the money, and pm'ed you my details
thanks.
scott.
i just want to say a big thanks for dropping off the tyres this morning, its not like i just live around the corner from your shop either, and i really appreciate it. i highly recommend them and will definately deal with in the future. i left feedback for you guys as well.
thanks.
scott.
Hi Guys,
We have been selling these for while now and can get them real quick, so if you need good handling tyres like the KU36. Please give us a call..
Designed for SCCA racing that demands high Uniform Tire Quality Grades, this incredible tire delivers unrivaled dry grip with split-second steering response, and its unique footprint is designed to deliver consistent handling performance at high G-forces.
Special Features
* Low void asymmetric tread pattern with circumferential grooving for high cornering grip.
* Ultra fine carbon black compounding for maximum traction.
* Ultra wide tread contact with highly rounded shoulders for optimized footprint shape during high lateral loads.
* Developed for quick autocross warm-up while maintaining race track durability.
* With a W speed rating, the tire delivers an optimum run temperature of 203 degrees Fahrenheit.
* UTQG rating of 180 AA/A.
Comparable Competitor Products
Falken Azenis RT-615, Yokohama ADVAN Neova AD07
may i please have a cost on 4x 205/50/15 delivered to tas 7250.
thanks.! :)
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
