  • Replies 121
hey champ how much for 2 x 235/40/18 KU36, 2 x 275/35/18 KU36 shipped to wetherill park, nsw 2164? if possible could i get a pricing on KU31's in the same sizes please shipped to same area thanx
Hey mate
How much for the following Options with Postage to Coopers Plains, QLD, 4108:
KU31: 235/40/R18 - 4 of: $
KU36: 235/40/R18 - 4 of: $
KU31: 235x45x17 - each: $
KU36: 235x45x17 - each: $
KU31: 255x40x17 - each: $
KU36: 255x40x17 - each: $
Currently working out my options with replacing tyres, or new wheels in staggered fit... either way will be buying a set of 4.
Cheers
Nathan
