Hello I have a Highflow R33 turbo with the 45v3 front cover and larger steel wheels front and rear for sale. Been using turbo on my car for the past 10000kms and it has not seen over 14psi boost. Turbo was freshly rebuilt before i purchased and has minimal shaft play and no chipped blades etc.
Has a HKS adjustable wastegate actuator attached as well as speedflow fittings for the water lines on each side if buyer requests. Does not come with braided hoses as i will be using these on the new setup.
I had MTQ in townsville check over the turbo when i purchased it and they said it would handle 18psi although i've never had it anywhere near this amount due to still running standard injectors and wanting to be safe on the turbo.
Reason for sale is upgrading to a larger turbo and need to sell this to fund purchase. Can sell with dump pipe if buyer requests.
PM me if interested.
Cheers.
Pictures:
Edited by JET-25L
$800 but feel free to make an offer. It's only an expression of interest but if i get a good price i'll take it off as i'm happy to hold onto it for a while if need be.
Cheers.
if i had seen this 3days ago i woulda bought it, i'm currently getting a hyflow made and its more than $800, This is a good deal and will be awesome. Good luck with sale, free bump.
Cheers.
Not sure who did the highflow and it is a non ball-bearing unit.
Please pm with any questions.
Cheers.
Looks like a Slide Highflow, does the core oil feed have a flange setup similar in look to the usual oil drain one?
The oil feed is a two bolt outside and feed inside type setup. However i use it with the standard oil feed hard line and don't use the two outside threads
Thats a slide high flow core and the wheels and machining look just like theirs too so would say it would be one of theirs
Yeah i always thought it was a slide highflow for some reason, i think i came across one a while back and it looked exactly the same. Cheers for the confirmation thought.
Great turbo!:D
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
