We are meeting at Galleria Shopping Center on Friday, the 18th of September 8pm, departing around 8:45pm. Galleria is located on the corner of Walter Rd West and Collier Rd
The map will be available from the meet point for a GOLD COIN donation. The money will be going towards the SilviaWA club display for Powercruise.
We place a strong emphasis on safe driving at all our cruises, so if you intend to come along please obey the road rules.
So cruise on down for a chat and also check out some hot modified cars.
Regards
Krystal
Edited by SweeT
https://www.sau.com.au/forums/topic/284461-another-friday-night-cruise/
haha i saw everyone drive past Tuart Hill maccas at about 9ish. Sounded so nice, i high beamed a couple of u but didnt know if u saw me or not lol. i was waiting to go on the antilag bubbles cruise but now i wish i went with u :blush:.
Saw NR 32 WA on Charles st ?? crossing to get fuel. Oh hai Nick >_< Havnt seen the dirty two in a while, looking good :D
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
