hey guys here is my 07 ktm 250 sxf, Things done to the bike include, fork air bleeders, bash plate. had factory fork oil takin out and put new oil in. Have got a new hi comp piston put in at about 50 hours has now got 60 something hours on it. Has had oil changed every 5 hours and air filter cleaned every ride. valve clearance checked bout every 10 hours but they havent changed so i recon i would leave em for 20-30 with out checkin again. Just put new custom graphics on and new shrouds. This is by far the best bike iv owned nothin beats the ktm highest quality, never had a problem with it. after buying this i will only buy ktms from now on. Went for a ride and wore my knee braces out side of my pants and it scratched and pealed back a bit of the graphics on the shrounds. its not real bad, can get new stickers for them on request, they were bought from newzealand and custom made so may take some time to get em here. Its not very bad cant really even see them in the pic. This bike has never been raced only just mukin around with mates in the bush or on mates land. Can organise a test ride if you live near here (traralgon) or come down for one. Nothing needs doin to the bike tyres have heaps of tread brakes have heaps left. Only sellin due to need some money. May trade for a cheaper bike plus cash adjustment or certain cars. wouldnt mind a cheap slider.
https://www.sau.com.au/forums/topic/284495-fs-or-swaps-07-ktm-250sxf/
  • 1 month later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
