I imported this car approximately 2 years ago, has been my daily driver since. NO accident history, only ~10,000kms since major service - had timing belt, water pump etc all replaced.
Recently replaced clutch with exedy heavy duty item, only 5-10,000kms old. Flywheel was machined at same time. Tyres are Nexen 225/45 in good condition.
Has following extras:
- Nismo 260km/h dash cluster
- Front and rear adjustable strut braces
- GAB coilovers
- Series 1 R33 turbo running 14psi
- FMIC
- HKS pod filter
- Dr Drift remapped ECU (dyno'd at ~175rwkw)
- Apexi EL boost gauge
- GTR fuel pump
- Dark tint on rear windows
- Razo gearknob + pedals
- Full 3'' exhaust including split dump/front pipe
- Rims on front are Manaray Vr5, and genuine 3 piece Linearetta on the rear.
- Also comes with Knightsports electronic boost controller, though not hooked up
- Has after market head unit + front 6'' speakers, with 8'' JBL sub
Car is good on fuel, I get 450-500+km per tank with little freeway driving.
Boot has just been professionally welded and painted following removal of spoiler.
All paint and panels are in very good condition compared to most other cars of this age, come and see for yourself.
Price is $9000
Located in S.E melbourne.
Contact Will on 0432928702
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
