im guessing you mean this?
http://www.carsales.com.au/used-cars/priva...amp;distance=25
you know u can just copy and paste the ad? will get a whole lot more interest on this site anyway~
Edited by tricky_dan
Brief Comments
One of the tidiest R32 GTS-T's around. Cooler...PowerFC....Eboost etc....
comments
Sadly the time has come to depart with my Skyline
as a 4 door is now required.
It is very clean and i regularly get told the same by strangers.
I have owned the car for around 4 years and am the 2nd Australian owner
and was purchased with 60,000 klms on it.
It has been serviced by Bezerkly Automotive in Wollongong
who did most of the Skylines in the area and oil has been changed every 5000
ks.
The car Features.........
3 inch Exhaust.....
Front Mount Intercooler....
Splitfire Panel Filter....
Eboost Boost controller....
APEXi Power FC computer and Hand controller Tuned by "Hitman" Engine management on Standard Turbo on 14 Psi 175 RWKW....
R34 GTT Wheels as seen painted black....
R32 GTR Front 4 piston brake upgrade....
GTR Replica front bar....
GTR Grille and Modified bonnet to suit....
Spoiler removed and holes welded over and repainted by a panel shop....
Exceedy Clutch....
Just Jap Alloy Radiator....
Silicone Hoses....
Just Jap aftermarket coils to fix the Skyline Misfire....
New Leather Gear Boot and handbrake surrounds.....
Car has been through a full EPA inspection and
passes the noise (by 1 DB)
and the emissions test easily.
All the tests are kept in a folder in the car so
if you get hassled by the Po-Po or the EPA whilst out and about you can show them the test results
and avoid the hassle.
Nigel.
Wollongong NSW
$12500 ono
0411022554
Edited by IBOO57
  • 3 weeks later...
  • 4 weeks later...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
