Nokia N97 - $850
Touch screen isn't for me, camera is great though, I am cutting my losses and going to buy an E75, unfortunately I'm stuck on a f**king $69 cap, so I have to sell my handset and buy a new one cos they won't let me change handsets >.<
Located in St.Lucia, Brisbane
(can post)
Item will come all wraped up in oem plastics and box, practically brand new, works fine, the userbility factor is just not for me, I prefer buttons.
Contact Michael on 0413 504 084
Thanks,
https://www.sau.com.au/forums/topic/284942-nokia-n97/
you might wanna drop the price a bit man. you can buy them brand new in box never touched straight off the shelf from shopbot for under $800 from unique mobiles, becex tech, portagadgets, citishop, optus, bluefly mobile and more...
Just thought you might wanna know why you r getting no hits.
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4787188
Are you serious????????? The reason I went on a plan was cos VODAFONE wanted $1200 for me to buy the phone out right! :)
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4787835
I checked out that site, all I can say is this economy shit is f**ken bullshit. The price of them has dropped down to 800'ish, a few months ago they were selling for over $1100, what a f**ken rort :P
Price drop to $800
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4789203
Iv got one of these.
Its a really great phone for those who like touch screen or the QWERTY key board.
Heaps of cool "iPhone like" features.
GOODLUCK mate.
many apps out for it yet?
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4790542
New First Post since it won't let me edit my first post:
Nokia N97 32GB - $700
Touch screen isn't for me, camera is great though, I am cutting my losses and going to buy an N95 8GB, unfortunately I'm stuck on a f**king $69 cap, so I have to sell my handset and buy a new one cos they won't let me change handsets :D
(can post)
Item will come all wraped up in oem plastics and box, practically brand new (less than a month old), works fine, the userbility factor is just not for me, I prefer buttons.
Contents
- Nokie N97 32GB
- Nokia Battery
- OEM Charger
- Nokia Stylus for optional use on touch screen
- Nokia Cleaning Cloth
- Nokia USB Cable for PC connectivity and also chargers the phone whilst connected
- Nokia OVi PC Software
- Nokia Car Charger with dual adapter for different sized power plugs (can charge all Nokias)
- Nokia Headphone jack/volume control for handsfree
- Nokia Manuels/Brochures etc
- Nokia OEM Soft Case
- Custom made hard case (cost me $40 to buy and have modified to fit)
Thanks,
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4806747
Ive got an N95 8gig, little bit of the usual wear marks on it, interested ina trade with cash your way?
If so i will get pics of it.
Maybe, are you local? If so I'll check it out, but yeah $650-700'ish is enough for me to buy a brand new one which is what I'd prefer to do :D
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4806778
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
