Is there any fundamental reason im missing that would be causing the engine to ping???? i have basic knowledge only.
ECU has been remapped. r34 SMIC. Full exhaust. EBC. AFR 11.6 or thereabouts.
Of late the car has developed engine rattle on booth boost settings (10 & 12). Ive since had timing reduced from the CAS whilst i find out whats the cause. On 10psi it produced around 185RWKw on the dyno with apparently no rattle after timing was reduced slightly. Ive since noticed it ping slightly on the street (had a few warmer days) on 10psi.
I suspected faulty fuel pump (its standard), but surely if thats the case you would see the mixtures leaning out?? This isnt happening.
Any ideas would be appreciated. i just purchased a return flow intercooler (justjap) in a hope this might rectify it somewhat. Im also going to grab a Bosch 040 just to be sure. The plan was to be able to confidently run 12psi achieving around 200RWKw without the engine pinging its fkn brain out. Many others before me have achieved this.
This week out of curiosity i filled it with 98 octane PLUS Nulon Octane Booster at 30 bucks a bottle. It seems to have helped but surely this isnt a necessity to run without detonating?? Is there anything obvious to check and/or recommend replacement whilst im having the intercooler and fuel pump installed???
https://www.sau.com.au/forums/topic/285122-r33-gts25t/
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
