Up for sale is my 1994 R33, it comes with few extras like:
3inch turbo back exhaust, drift twin pipes,
trust intercooler,
trust panel filter,
trust timing belt
Bosch hi volume fuel pump (500HP rated),
NEW airflow meter,
NEW battery,
slotted rotors all around using endless SS pads,
lowered with adjustable Tein coilovers,
17x8F 17x9R Work professor SSR JAP rims,
2 tyres 4 months old the other 2 need to be replaced soonish,
Red line diff and gearbox oil,
EXEDY 5 puck brass button clutch,
platinum spark plugs,
Always serviced every 5000km with motul turbolight oil,
it has done 163 000km but it is in good condition overall no problems at all,
ALL OFFERS WILL BE CONSIDERED
Will sell for $1000 less with stock black wheels
Edited by bokee
https://www.sau.com.au/forums/topic/285233-r33-for-sale/#findComment-4808063
PRICE DROP $9000 or near offer as i need it gone by the end of october
yes it has done a bit more km but at least i know they are genuine. I had never had any problems with it except the battery and i had to replace the airflow meter. I have another car coming from japan and i need this gone so throw me an offerrrrrrr
https://www.sau.com.au/forums/topic/285233-r33-for-sale/#findComment-4818691
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
