from Hyper rev the most popular Size in Japan for Staggered size is 245/35 19 and 275/35 19 which should disrupt the the VDC and closer to the speed read accuracy.
Yes those are the most popular size... I have that too
it's a very good proportional change where these sizes is 0.85% smaller in circumference (less than 1%) at the front
and 0.38% smaller in circumference at the rear. There is only 0.5% disproportional circumference front to rear which means
it is quite small that the VDC may not even detect the changes.
so whats the tolerance like? i mean in terms of % difference in diameter
would a 235/35 19 and 275/30 19 work???
If you haven't got to the bottom of it, this size you have is 1.9% reduction in circumference at the front and 4.4% reduction at the rear.
There is around 2.5% disproportional circumference front to rear which may be 'huge' enough to make the VDC computer thinks
either front or rear tyres are slipping all the time... it may upset the VDC. How big is that tolerance we do not know.
I think the tyre shop who gave you that combination must have assumed your coupe comes with non-staggered OEM tyre size front to rear.
Reason is because the front and rear circumference are just differ by 2mm. Where in fact they should have given you a bigger profile tyre
at the rear - you'll find 265/35 19 will work with your 235/35 19, alternatively use the sizes what pw350gt suggested above.
You can't use 275/35 19 at the back because that will be disproportionally too large compared to your front, so you must change the front
to 245/35 19 as well.
sorry for the Typo if any one didn't get it.
What i meant is those size Should NOT disrupt the VDC..
VDC relies on the ABS sensors to tell the computer how fast each wheel is spinning. The other input into the VDC computer is a yaw sensor in the middle of the car. That detects accelerative forces on the car, so the computer can work out of the car's acceleration and turning rates line up with what the ABS sensors are telling the ECU as to how fast the wheels are spinning.
If that data does not correspond with "normal", it'll cut power to the engine by closing the throttle and it may grab the brakes as well.
You can unplug the VDC module. Your dash will light up like a Christmas tree and you'll lose the speedo/odo/ABS but the brakes will still work. If the car drives "normally" then you've found your culprit. Whether its the ABS or yaw sensor will require investigation.
Normally when the VDC detects a fault it'll just shut itself off as if you'd unplugged it as above. Its strange that the unit is just working overtime.
Josh at Pro Concept has a spare 6 speed manual gearbox. I'm not sure how negotiable on that price he is, but you can give him a call. Find out if its necessary though. If turning off VDC stops it then its not a transmission issue.
Tell him that you're after the spare 350Z gearbox that was in Alan's car for a while.
Excellent , thanks just what i needed to know. I did go for a shortr drive last night and i had the VDC switched off and didnt have a problem , but i didnt push too hard. Then when i stopped and then started the car again i drove off and the VDC OFF light wasn't lite on the dash so im ashumming it automatically turns back on when you re start the car. And the before 100m i had the same problem , slip light came on and the car wouldnt give power and bad noises from somewhere.
Why cant i just drive the car with the VDC OFF all the time. Is there any damage or could i do any more damage driving it?
The lube mobile guy didnt have a clue or where to plug in the computer for help !!
The OBD-II port should be somewhere under dash panel on driver's side under steering wheels - just like any nissan. Impul ECU is probably only a chip swap, so most obd reading might still work, give it a try...
If VDC relies on ABS sensor as said, might worth checking if the sensors are functioning ok. not damaged etc.
Why not try Nissan dealer that knows or done a 350Z? If the lube mobile guy dunno how to fix it?
It does. You can buy aftermarket modules to have it "remember" your last setting.
You can. I do it all the time (well, TCS since I don't have VDC). The VDC is an electronic system that is meant to only work reactively. If you drive normally you should never make it work. It just means that you won't have the "safety net" of the stability control.
If the car's perfectly drivable without VDC then take it to a mechanic's. I don't know about Paden, but Pro Concept has a Nissan OBD scanner that works with our cars. As does CRD. Maybe drop them a PM, since they're on SAU?
Since the car's drivable with VDC off, you could test the ABS sensors by triggering it. Pump the tyres up to their maximum rated pressure, find somewhere open and deserted, drive it up to a reasonable speed, and jump on the brakes. If the ABS works then their sensors work. You're looking at either a yaw sensor issue, or electronics.
If the brakes lock up, then you can go to any mechanic and ask them to check your ABS sensors first. Its common technology that doesn't require V35 specific knowledge to troubleshoot.
Just remember to dump the air pressure afterwards, to get a bit more grip back.
FYI the VDC module/ABS pump is bullshit expensive new, but I have seen quite a few on eBay USA for not a great deal of cash. You're luckier than me - my car has TCS only and my pumps are impossible to find. eBay / Yahoo! Auctions Japan only have non-TCS units for base model cars, or VDC units for top-spec ones.
The port is above the right-side knee on the driver's side. The Lube Mobile guys can be idiots sometimes - a mate of mine had a MR2 and the Lube Mobile guy went to the front of the car to check the engine.
Yeah I have a 350Z.
Well i have been driving around town just keeping it short sorta hoping for it to do it again and it did. I had the VDC switched OFF and i have discovered whilst the car in not level the slip light comes on and a definate grinding sound from the front of the car.
I think my only option is to take it to nissan , unless you guys can tell me a cheaper option ?
maths looks complicated. But I plugged the tyre measurements in 1010tires.com for comparison and this is what it came up with
Tire 1 - 235/35R19 >Search Tires Tire 2 - 275/30R19 >Search Tires
Section Width: - -
Section Width: 9.25 in 235 mm
Section Width: 10.82 in 275 mm
Rim Diameter: - -
Rim Diameter: 19 in 482.6 mm
Rim Width Range:
Rim Width Range: 8 - 9.5 in
Rim Width Range: 9.5 - 11 in
Overall Diameter: - -
Overall Diameter: 25.47 in 646.93 mm
Overall Diameter: 25.49 in 647.44 mm
Sidewall Height: - -
Sidewall Height: 3.23 in 82.042 mm
Sidewall Height: 3.24 in 82.296 mm
Radius: - -
Radius: 12.73 in 323.34 mm
Radius: 12.74 in 323.59 mm
Circumference: - -
Circumference: 80.01 in 2032.2 mm
Circumference: 80.07 in 2033.7 mm
Revs per Mile: -
Revs per Mile: 816.6
Revs per Mile: 816.0
So to me that looks close enough on the difference on circumference, unless I'm totally missing the point again?
Being an import, Nissan Aus may not touch it. It has plenty in common with the Z33, but you know what stealerships are like with greys.....
Try Pro Concept otherwise. Josh has a Consult computer that can be plugged in to the OBDII port. If the dash lights up that badly, it'll probably be returning error codes. He's also quite familiar with the platform, and aware that it has electronics issues.
He's not cheap, but you get what you pay for.
I've never been to Paden so I don't know what gear he has at his disposal, but I know Josh has the equipment and experience to be a good "first bet" for troubleshooting the fault. If Paden can read ECU trouble codes, and you've got previous experience with him, then I'd suggest contacting him first.
yes you did it again.... :-)
put tyre 1 as 225/45/18 (your front OEM) and tyre 2 your desired aftermarket (235/35/19)
compare the 2, and note the % of decrease or increase in circumference between the two. call this 'a'
this is probably not on tire1010.com but it's easy:
(oem circumference - new circumference) divided by oem circumference times 100% = the % you're after
then re do the calc above and this time put tyre 1 as 245/45/18 (your rear OEM) and tyre 2 your desired new rear tyre (275/30/19)
compare the 2, and not the % of decrease or increase that happens. call this 'b'
to prevent VDC playing up or getting confused, you need to make sure 'a' & 'b' are as close as possible.
the reason why you can't compare your 235/35/19 to 275/30/19 is because your OEM tyre on V35 is staggered.
V35 tyres are intentionally bigger at the rear. your method above will only apply if your OEM tyre size on the V35 is not staggered
(e.g. V35 sedan or AWD GTR).
So you must always compare OEM front vs new front and OEM rear vs new rear, and make sure the % differences
on each axle is the same... e.g. if the new front is 1% smaller than OEM front, the new rear must be 1% smaller than OEM rear.
ah ok....that totally makes sense now. I didn't realise that the coupe's came with staggered sizes from the factory. I was comparing this with my beemer where I had the same problem but managed to run staggered because the overall diameter were almost equal (factory tyres were same profile front and rear).
Edited by fcruz3r
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
