Any1 wants to buy a brand new A'PEXi AVCR???
we need at least 5 or more ppl to buy together...
i think the price in aus is around 900~1000, correct me if i'm wrong
I'm gonna to order them from HK
it will take about 2 weeks time b4 they arrive
The price will be around 500~600 depends how many ppl buying
i'm in Brisbane, so ppl from Brisbane/Gold Coast area only
now...only 2 ppl buying....so we need 3 more ppl
if interested...plz give me a call on 0433135474
PS ppl wants to buy other performance parts can also ordered together
cheers
Daniel
https://www.sau.com.au/forums/topic/28555-apexi-avcr/
  • Replies 41
NismoGirl:
Thanks for the correction....
i went to some shop they quote me for 900.... :D
i thought it's a bit too high, therefore, i decided to buy it from HK, which is still cheaper than australia
Slamm:
If you are interested, then plz give me a call...
we should arrange a time to meet up
i live in Sunnybank....
cheers
Daniel
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-590920
Im of the opinion that AVCR isnt that hard to fit yourself
its the SAFCII thats hard
ide just get both and get both installed at the same time
Why do you say the SAFCII is hard to install knore?
I've got one in the mail and I was intending on doing it myself (installing that is, I'll leave the tuning to the experts)
You've got me all worried now...
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593547
avcr is easy to install and tune your self - but its crap.. only single soleniod. Get a HKS or Greddy.
SAFC is easy enough to install, but not tune yourself.
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593563
Thanks dAVE.  As I thought...
Benefits of duel solenoid over single solenoid?
Not sure how it works but I know it makes boost come on better. There are many threads about this on the forums. Also price wise, you can get a greddy profec B for 450 new and it has duel solenoid... you just dont get the riced up screen, but the HKS EVC 4 has that :cheers:.. and alot more classy than apexi.
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593580
A searching we will go...
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593581
While we are 1/2 on the topic here, i've got a S-AFCII in the mail coming over and i've read the wiring diagram on the apexi website, it doesnt seem hard to install and i think i could do it myself.
What i wanna know is after i directly install it can i drive the car without it being tuned, like does it have a base map or still use the exisitng ecu's A/F ratio untill its tuned?
If i do this it will save me $$$ on the install and ill leave the tuning for the experts
Thanks
Matt
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593884
MJ,
So long as you can install the unit ok and set it up as per the instructions (ie cylinders, tps, afm settings) you will be fine.
The SAFC will be effectively zeroed out and wont make any changes to the air flow signal.
This is exactly what I intend on doing with mine until it goes on the dyno...
NismoGirl:
You wouldn't happen to know if Gavin tunes the SAFCII's would you? Approx price? He uses Dysons dyno doesn't he?
Your gunna have to start compiling a price list for him... j/k :cheers:
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593901
Thanks for that strutto, i shouldnt have any drama's setting it up, but if i do i guess thats what these forums are for hehe.
I'm thinking of getting Gavin to tune mine too....but i suspect he will be pricy as he will have to use someone else's dyno. Whats the name of the workshop that Gavin uses's for the dyno? could be easiest just to goto straight to that place?
Cheers,
Matt
P.S sorry for the hijack
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593966
I just asked the same question re the dyno... I believe he uses Dyson Rotarys dyno but I could be wrong...
I don't want to bag the workshop but I wouldn't let the guys at Dyson tune mine... Same way I wouldn't let Gavin tune my rotor if I had one... (Not that thats gunna happen)
I've seen some of his (dysons) tunes and haven't been overly impressed...
P.S This is like the biggest hijack I've been in ever... And it doesn't seem to be stopping either... :D
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593982
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
