What: 89 R32 GTR
KMs: 86xxx
Contact: Paul 0411 870 159 or through here.
Dollars: 15k. (Few recent invoices - 6.5k for hp, 2.5k suspension, 3k wheels/tyres, etc - it's all done) Going back to an NA cheapie for mobile business. (May look at trades + cash)
At a glance: Just gave it a full gonig over so it's exactly how I want it, stops - goes - and handles properly. Probably only 2000km on everything. 350awhp (fresh tune on 4WD dyno) Vipec ECU, twin plate clutch (very easy to use), fresh brakes, N1 turbos, Bilsteins/full Whiteline setup, 17x9.5 Origin wheels, etc. Did timing belt/idlers/water pump/100k service while it was all happening. Factory wing + a sub/amp comes with the car.
Condition: She's not about to win any shows, but you can get straight in and go for it. This is for the person who values performance and setup.
I built this as a tough do-it-all street car, but running my own mobile business = time for another boring car. Does daily duties with ease. Had a minor nudge on the left side, wheel alignment was not affected. Pics show the action. Just a bit of lovin on the 1/4's and left edge of rear bar. Been like that for a bit, doesn't bother me, but priced to take this into account. Has since had another wheel alignment to fine tune front end settings. Few little things done recently like tie rod end/rack end/rack boots.
Pre-existing parts are noted, everything else has just been put on within the last couple of thousand kms.
Engine
N1 turbos (came on car)
ATI balancer
Splitfire coils
HKS front mount + piping (came on car)
Pod filters (came on car)
Vipec ECU
New timing belt/water pump etc
Fuel
Bosch 040 intank pump
Turbosmart adj fuel pressure reg
Siemens 610cc injectors
Suspension (Whiteline/Sydneykid setup)
Bilsteins with height adj
King springs
Adj camber/caster bushes
Front/rear swaybars
HICAS lock bar (HICAS removed)
Driveline
17x9.5 Origin DNA01 wheels (rash on left ones)
Twin plate clutch (easy to drive - was already in the car)
Falken FK452 255/40/17 tyres
Brakes
Slotted rotors
Braided lines (ADR approved)
Fresh Motul high temp fluid
RB74 pads
Interior
MOMO steering wheel (came on car)
MOMO gear knob
Blitz dual channel boost controller - 4 maps, lots of adjustment, works well. (came on car)
Blitz boost guage
Alarm/immobiliser that winds the windows up for you
Turbo timer
Forgot to mention...
Exhaust
Trust split front pipe
Highflow metal cat
Exhaust (Trust from memory)
If doing a trade + cash would want at least 10k cash, just getting an NA cheapie.
would you consider a r33 NA (few mods) plus about 6K cash?
I would consider an NA 33, but I plan on spending 5k or less on a work car, hence the requirement of 10k cash if doing a swap. I'd prefer a straight out sale, but swap + cash can be very convenient for both parties.
Car also has an alloy radiator + silicone hoses
How much damage is done to the panels?
Can you get a quote on fixing the damage?
Damage is shown in the pics and described in the first post, it didn't even change the wheel alignment so it was pretty minor. - Going in for a quote at a proper panel shop on Friday, I'll let you know.
PM sent to johnbarry.
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
