So! After taking it to see Aaron at InTune, turns out not only has the gasket gone on the cat, the flanges and gaskets back from the cat are leaking aswel. I've lost about 2-3psi top end now coz of it heh. Looks like I Have 2 choices, either I can replace the flanges and gaskets, bout $500 total, or I can get a 3.5" xforce system cat back stainless steel system for bout $1500 installed.
Requires new cat though aswel, so as the front pipe can marry up to cat properly. At the moment it's 4" front to 3" cat, hence the extra price.
Well, doesn't actually require a new cat, but different cat will supposedly be able to marry up to the front pipe better
Edited by stormtrooper
Going to grab a replacement gasket from Xspeed this week and replace it on saturday myself. Looked over the zorst last night and from what I could tell there was nothing leaking past the cat itself (on the back end). Replace it and see how I go :)
Replaced the front pipe -> cat gasket yesterday. The old gasket on the flange was black as night and was on both the top and bottom, back and front of the gasket. Definately blown out. Replaced it with a nice shiney new one and fitted it back up with high temp gasket goo. Beautiful. No more leak coming from the gasket. However! One of the f**king welds holding the Cat pipe itself to the flange where it marries the gasket to the front pipe flange, has a bloody leak in it :bunny: It's not a huge leak, VERY minor but could feel it when I had my hand over the join when I had the motor running testing it. Damn. Well, I've re-gained about 2psi aswel and should hold till I can afford to replace the system heh.
That cat in there is a metalcat so it's not a cheapy to just throw away for the sake of it plus it would have only done 10000km max. Chris, if you want a replacement stainless exhaust look up some old threads from Kermit. He should be able to do you a stainless cat back, tucked right up to the body for 6-700. He's very fussy about his work and he put the cannon on your car. Do recommend!
Hopefully he still does the work
Nice one :ph34r: I gave her a little boot today on the freeway on the way into work (sat back at 80, 3rd, foot down to 100) and hit full 16psi again. Was an exhaust issue.
I'll probably do that too Travis. The only thing I am worried about is that when I pulled the cat/front pipe apart, the actual internal diameter of the front pipe is about 1inch larger than the internal diameter of the cat pipe. So I am just worried that it could be a potential bottle-neck in the system. Wouldn't mind some people's thoughts on this too (if you have any thoughts that is considering barely anyone raised an eyebrow of interest to help out in the first place).
  • 3 weeks later...
Ok, seems like I havn't regained all boost again. It holds full boost most of the time but when she hits around 75-80+C water temp, starts "flapping" at about 14psi+ (like hits about 14-15 and the needle sits there swinging back and forth a little). Wondering if this could be a cracked hose or something that is expanding to let air out when it's hot as opposed to being constricted when it's colder?
i dont think going from 4 inch to 3 inch is going to cause a bottleneck. There simply isnt enough gas to cause such a high pressure restriction in a massive 4 inch pipe.
Also, dont go by what the greddy gauge tells you, that thing is affected easily by bumps in the road and stuff. It juts around everywhere haha I always looked at the read out on the boost controller
Ah nice one. Yeah from what I have noticed it will hit full on the boost guage, then drop down a little and bounce back and forth as you said. I changed out the coilpack on #1 cyl yesterday too and she seems happier at higher revs now aswel. I know that on Rb26DETT motors the front 3 cyls power the front turbo and same for the rear 3 cyls with the rear turbo, could something like limited spark from the dodgy coilpack cause the front turbo to not fully spool or to pike out a bit at high revs/high temp? Rather random thought but still thought I'd ask it hehe.
;) I just read too much into things sometime and like to throw it out there in case.
The boost controller doesn't lie, the guage does.
Cleaned the AFM's out with degreaser then Mass Airflow Meter cleaner yesterday but still hunting when she's hot. Think it IS time for a retune. Nuff said :P Close thread heh.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
